[gdal-dev] weird slope map
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Mon May 20 12:30:37 PDT 2013
Ahmet Temiz <ahmettemiz88 <at> gmail.com> writes:
> Hello
> I obtained steplike slope map from elevation iso lines.
> What are the likely problems ?
Can you give us a sample of your source data and the exact commands you have
used? Perhaps also some example about what you would like to get as a result.
Regards,
-Jukka Rahkonen-
