[gdal-dev] Problems when mixing https calls
Ari Jolma ari.jolma at gmail.com
Tue May 21 01:07:07 PDT 2013
On 05/21/2013 10:57 AM, Even Rouault wrote:
> Selon Ari Jolma <ari.jolma at gmail.com>:
>> Even,
>> Another strange thing with GDAL WFS driver. Earlier it did not try to
>> access the HEAD of a XXX.resolved.gml and now it does:
>> Here's an excerpt from my server logs. These calls are created by GDAL,
>> the first is a good GetFeature call, which gets 215633 bytes of GML and
>> the next is bogus. I can see this made up in ogrgmldatasource.cpp but do
>> not understand why. In February this did not happen and GDAL parsed the
>> GML the WFS provided fine (it actually created by GDAL too).
>> 213.157.86.72 - ajolma [21/May/2013:00:02:56 +0300] "GET
> /OILRISK-protected/wfs.pl?SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=OILRISK.vtest.geom
>> HTTP/1.1" 200 215633
>> 213.157.86.72 - ajolma [21/May/2013:00:02:58 +0300] "HEAD
> /OILRISK-protected/wfs.pl?SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=OILRISK.vtest.resolved.gml
>> HTTP/1.1" 200 -
>> Do you have an idea what's going on here?
> Ari,
> I don't remind a recent change that might have affected this (but my memory can
> be fragile), but reviewing the GML driver code, the fact that .resolved.gml is
> probed means that the GML driver doesn't recognize the first bytes of the
> GetFeature response to be a GML WFS document. Could you paste them ?
<?xml version="1.0" encoding="utf-8" ?>
<ogr:FeatureCollection
      xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
      xsi:schemaLocation="http://ogr.maptools.org/ .xsd"
      xmlns:ogr="http://ogr.maptools.org/"
      xmlns:gml="http://www.opengis.net/gml">
   <gml:featureMember>
     <ogr:vtest_geom_  fid="vtest_geom_.0">
       <ogr:geometryProperty><gml:Point  srsName="EPSG:3067"><gml:coordinates>185607.11328746471554,6718884.468898030929267</gml:coordinates></gml:Point></ogr:geometryProperty>
       <ogr:id>6483</ogr:id>
     </ogr:vtest_geom_>
   </gml:featureMember>
>   My
> hypothesis would be that the FeatureCollection root element is in a XML
> namespace different from none, gml or wfs.
It seems to be in ogr (it's made by GDAL). I'll try changing that.
> Does the probing of .resolved.gml, apart from slowing down the process, prevent
> the driver to parse the GetFeature document ?
yes, the resolved.gml is not older than the GetFeature doc, thus it is
used and found to be empty. I commented that out but it still can't
parse the features.
>   I think it should not, but there
> might be subtle issues since it will probably not use the schema obtained with
> DescribeFeatureType to return the GML layer.
It is using the schema it got from DescribeFeature.
About the OpenSSL problem. I can probably bypass it by using only Curl
(there are Perl bindings to Curl)
Ari
> Even
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130521/f0163e0e/attachment.html>
