[gdal-dev] multiple access to a file
Jose Gomez-Dans jgomezdans at gmail.com
Tue May 21 03:30:19 PDT 2013
Hi Frank,
On 21 May 2013 00:02, Frank Warmerdam <warmerdam at pobox.com> wrote:
> If you write a small part of an image, GDAL is likely to read a larger
> area, update that and write it back.  If other programs happen to try and
> update the same larger area at the same time some data is likely to be
> lost.
Thanks for your reply. However, locking the output files would still work?
Provided the cache has been flushed between the open/close dataset calls,
it should be fine?
Thanks!
Jose
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130521/e65cb92a/attachment.html>
