[gdal-dev] [PostGis-raster] Unnecessary Extent SQL query on GetCoverage request
Jorge Arevalo jorgearevalo at libregis.org
Tue May 21 08:43:37 PDT 2013
Hello Jean-François,
I now it's late to answer this question. Sorry for that.
You couldn't avoid that query because was raised by the GDAL PostGIS Raster
driver. I'm working on some improvements right now, and that's one of the
improvements actually made. I suggest you to get the last code from 1.10
branch, and give it a try. That should solve this problem.
Best regards,
Jorge
On Thu, Jan 17, 2013 at 9:10 PM, Jean-François Bourgon
<jfbourgon at gmail.com>wrote:
> I published a Postgis-raster table as a Mapserver WCS layer using
> gdal-1.10dev driver. I'm getting the expected result as output of my
> Getcoverage query but I'm concerned by the time required to extract the
> data. It takes about 3 minutes to extract a 4800 x 4800 pixels area. I
> looked at the SQL queries performed against the database during data
> processing and found that the GDAL driver execute a query in order to get
> the extent of my layer using the following SQL query:
> select srid, nbband, st_xmin(geom) as xmin, st_xmax(geom) as xmax,
> st_ymin(geom) as ymin, st_ymax(geom) as ymax
> from (select st_srid(rast) srid, st_extent(rast::geometry) geom,
> max(ST_NumBands(rast)) nbband from mib_postgis.gridcoverage_
> cdsm75 group by st_srid(rast)) foo;
> srid | nbband |       xmin        |       xmax        |       ymin
> |       ymax
> 4617 |      1 | -139.500104166667 | -52.0001041666667 | 41.5001041666667 |
> 60.0001041666667
> (1 row)
> Time: 153033.599 ms
> I'm wondering how I could avoid this SQL to be performed on each call,
> since it is consuming a large amount of the request processing time and
> values are always the same.
> Is it something that could be fixed at database level or into my mapfile.
> See the my current mapfile layer definition:
> LAYER
>     NAME cdsm
>     GROUP cdsm
>     METADATA
>       "wcs_label"           "cdsm"  ### required
>       "wcs_rangeset_name"   "Range 1"    ### required to support
> DescribeCoverage request
>       "wcs_rangeset_label"  "My Label"   ### required to support
>       "wcs_extent" "-139.500104166667 41.5001041666667 -52.0001041666667
> 60.0001041666667"
>       "wcs_resolution" "0.000208333333333 0.000208333333333"
>     END
>     TYPE RASTER
>     STATUS ON
>     PROCESSING "NODATA=255"
>     DATA "PG:host=hostname port=portnumber dbname='dbname' user='username'
> password='passwd' schema='schema' table='gridcoverage_cdsm75' mode='2'"
>     PROJECTION
>         "init=epsg:4617"
>     END
>   END
> Thanks,
> J-F
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Jorge Arevalo
Freelance developer
http://www.krop.com/jorgearevalo
http://about.me/jorgeas80
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130521/ce35aa63/attachment.html>
