[gdal-dev] GDAL 1.10 JP2000 Problem/Crash
Wed May 22 06:35:03 PDT 2013
Dennis,
There are several jpeg2000 drivers potentially available for gdal.  Do you
know which you are using?
Best regards,
 On May 22, 2013 5:20 AM, "Dennis Gocke" <dengo at gmx.net> wrote:
> Hi,
>  I’ve encountered a problem with Pleiades JP2 files from Astrium, GDAL
> crashes when opening the file.
> You should be able to reproduce the the crash by downloading a sample
> dataset from their page.
> http://www.astrium-geo.com/en/23-sample-imagery
> Optical Imagery->Pleiades->Pleiades Primary Product – Bundle
> You have to fill out the form and will then receive a download link via
> email.
> The crash happens with the file
> FCGC600031035/IMG_PHR1A_MS_002/IMG_PHR1A_MS_201202250025599_SEN_PRG_FC_5847-002_R1C1.JP2
> And I have other JP2 Pleiades files where it happens too, so it’s not
> related to this single file. Both ERDAS and ArcGIS are able to open the
> file.
>  If it’s not possible to open the files with GDAL, an appropriate error
> message instead of a crash would be good.
> Thanks for looking into it.
>  Cheers,
> Dennis
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130522/024414c9/attachment.html>
