[gdal-dev] GDAL 1.10 JP2000 Problem/Crash
Dennis Gocke dengo at gmx.net
Wed May 22 09:42:57 PDT 2013
I'm using the stable 1.10 build from Tamas' site.
GDALIdentifyDriver on the file reports: "ERDAS JPEG2000 (SDK 3.x)"
When trying to open the file I get an AccessViolationException.
Cheers,
Dennis
On Wed, May 22, 2013 at 3:35 PM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> Dennis,
> There are several jpeg2000 drivers potentially available for gdal.  Do you
> know which you are using?
> Best regards,
>  On May 22, 2013 5:20 AM, "Dennis Gocke" <dengo at gmx.net> wrote:
>> Hi,
>>  I’ve encountered a problem with Pleiades JP2 files from Astrium, GDAL
>> crashes when opening the file.
>> You should be able to reproduce the the crash by downloading a sample
>> dataset from their page.
>> http://www.astrium-geo.com/en/23-sample-imagery
>> Optical Imagery->Pleiades->Pleiades Primary Product – Bundle
>> You have to fill out the form and will then receive a download link via
>> email.
>> The crash happens with the file
>> FCGC600031035/IMG_PHR1A_MS_002/IMG_PHR1A_MS_201202250025599_SEN_PRG_FC_5847-002_R1C1.JP2
>> And I have other JP2 Pleiades files where it happens too, so it’s not
>> related to this single file. Both ERDAS and ArcGIS are able to open the
>> file.
>>  If it’s not possible to open the files with GDAL, an appropriate error
>> message instead of a crash would be good.
>> Thanks for looking into it.
>>  Cheers,
>> Dennis
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130522/ee533e1a/attachment.html>
