[gdal-dev] GDAL 1.10 JP2000 Problem/Crash
Wed May 22 10:22:09 PDT 2013
Dennis,
Ah.  In my experience the ECW SDK 3.3 JPEG2000 support is buggy and I was
never really able to trace down the issues.  I would encourage you to
consider alternatives - one possibility is the MrSID SDK's JPEG2000
support.  If Tamas's build includes MrSID support then all you need to do
is set the GDAL_SKIP environment variable to JP2ECW which would make GDAL
skip the ECW based driver.   If Tamas hasn't built with MrSID then it falls
to you to build GDAL which can be somewhat complicated.
Best regards,
Frank
On Wed, May 22, 2013 at 9:42 AM, Dennis Gocke <dengo at gmx.net> wrote:
> I'm using the stable 1.10 build from Tamas' site.
> GDALIdentifyDriver on the file reports: "ERDAS JPEG2000 (SDK 3.x)"
> When trying to open the file I get an AccessViolationException.
> Cheers,
> Dennis
> On Wed, May 22, 2013 at 3:35 PM, Frank Warmerdam <warmerdam at pobox.com>wrote:
>> Dennis,
>> There are several jpeg2000 drivers potentially available for gdal.  Do
>> you know which you are using?
>> Best regards,
>>  On May 22, 2013 5:20 AM, "Dennis Gocke" <dengo at gmx.net> wrote:
>>> Hi,
>>>  I’ve encountered a problem with Pleiades JP2 files from Astrium, GDAL
>>> crashes when opening the file.
>>> You should be able to reproduce the the crash by downloading a sample
>>> dataset from their page.
>>> http://www.astrium-geo.com/en/23-sample-imagery
>>> Optical Imagery->Pleiades->Pleiades Primary Product – Bundle
>>> You have to fill out the form and will then receive a download link via
>>> email.
>>> The crash happens with the file
>>> FCGC600031035/IMG_PHR1A_MS_002/IMG_PHR1A_MS_201202250025599_SEN_PRG_FC_5847-002_R1C1.JP2
>>> And I have other JP2 Pleiades files where it happens too, so it’s not
>>> related to this single file. Both ERDAS and ArcGIS are able to open the
>>> file.
>>>  If it’s not possible to open the files with GDAL, an appropriate error
>>> message instead of a crash would be good.
>>> Thanks for looking into it.
>>>  Cheers,
>>> Dennis
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130522/2e589079/attachment.html>
