[gdal-dev] GDAL 1.10 JP2000 Problem/Crash
Even Rouault even.rouault at mines-paris.org
Wed May 22 10:46:22 PDT 2013
Le mercredi 22 mai 2013 19:22:09, Frank Warmerdam a écrit :
> Dennis,
> Ah.  In my experience the ECW SDK 3.3 JPEG2000 support is buggy and I was
> never really able to trace down the issues.  I would encourage you to
> consider alternatives - one possibility is the MrSID SDK's JPEG2000
> support.  If Tamas's build includes MrSID support then all you need to do
> is set the GDAL_SKIP environment variable to JP2ECW which would make GDAL
> skip the ECW based driver.   If Tamas hasn't built with MrSID then it falls
> to you to build GDAL which can be somewhat complicated.
I can replicate the crash with the JP2ECW driver with ECW SDK 3.3. It occurs
actually in the SDK itself, not in GDAL, so nothing that we can really do
about that (except using GDAL API Proxy, see below). Newer versions of the SDK
don't produce this crash.
Frank's above suggestions are the way to go. Tamas' builds do include MrSID
support as a plugin (XXXX-mrsid.msi packages). But they also include the
OpenJPEG driver, which can successfully open this file and should be the next
driver used after skipping JP2ECW :
$ gdalinfo --config GDAL_SKIP JP2ECW
IMG_PHR1A_MS_201202250025599_SEN_PRG_FC_5847-002_R1C1.JP2
Driver: JP2OpenJPEG/JPEG-2000 driver based on OpenJPEG library
Files: IMG_PHR1A_MS_201202250025599_SEN_PRG_FC_5847-002_R1C1.JP2
        IMG_PHR1A_MS_201202250025599_SEN_PRG_FC_5847-002_R1C1.JP2.aux.xml
Size is 10000, 6191
Coordinate System is `'
GeoTransform =
  144.8407819720184, 2.303727068124578e-05, -3.011809327220197e-09
  -37.76248166104331, -9.154071614724073e-09, -1.808332187648097e-05
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  ( 144.8407820, -37.7624817)
Lower Left  ( 144.8407633, -37.8744355)
Upper Right ( 145.0711547, -37.7625732)
Lower Right ( 145.0711360, -37.8745270)
Center      ( 144.9559590, -37.8185044)
Band 1 Block=2048x2048 Type=UInt16, ColorInterp=Red
  Overviews: 5000x3095, 2500x1547, 1250x773, 625x386, 312x193
  Overviews: arbitrary
    NBITS=12
Band 2 Block=2048x2048 Type=UInt16, ColorInterp=Green
    NBITS=12
Band 3 Block=2048x2048 Type=UInt16, ColorInterp=Blue
    NBITS=12
Band 4 Block=2048x2048 Type=UInt16, ColorInterp=Alpha
    NBITS=12
If you want to use the JP2MrSID driver, you need to set --config GDAL_SKIP
"JP2ECW JPEG2000 JP2OPENJPEG"
> Dennis,
> I believe you can use Even's GDAL API Proxy to avoid crashes in third
>party libraries.  See:
> http://trac.osgeo.org/gdal/ticket/4979
Indeed,
$ gdalinfo  --config GDAL_API_PROXY YES
ERROR 1: Read from pipe failed
gdalinfo failed - unable to open
'/home/even/gdal/data/jpeg2000/FCGC600031035/IMG_PHR1A_MS_002/IMG_PHR1A_MS_201202250025599_SEN_PRG_FC_5847-002_R1C1.JP2'.
But that's only band-aid and you need to use another driver in order to open
the file successfully
Best regards,
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
