[gdal-dev] GDAL 1.10 JP2000 Problem/Crash
Even Rouault even.rouault at mines-paris.org
Thu May 23 10:51:27 PDT 2013
Le jeudi 23 mai 2013 15:34:26, Julien Malik a écrit :
> Hello Even,
> On 05/22/2013 07:46 PM, Even Rouault wrote:
> > Frank's above suggestions are the way to go. Tamas' builds do include
> > MrSID support as a plugin (XXXX-mrsid.msi packages). But they also
> > include the OpenJPEG driver, which can successfully open this file and
> > should be the next driver used after skipping JP2ECW :
> > $ gdalinfo --config GDAL_SKIP JP2ECW
> > IMG_PHR1A_MS_201202250025599_SEN_PRG_FC_5847-002_R1C1.JP2
> Does this mean that in an ideal "free software only" setup, OpenJPEG is
> now the default driver (used before Jasper) ?
This is not really new. The openjpeg driver has always been registered before
the jasper one.
> Thanks,
> Julien
Geospatial professional services
http://even.rouault.free.fr/services.html
