[gdal-dev] select shapes in a folder by geometry type
Eli Adam eadam at co.lincoln.or.us
Fri May 24 09:44:19 PDT 2013
If you are using a recent version can you ignore geometry type and use
the -dim 2 switch?
-dim val:(starting with GDAL 1.10) Force the coordinate dimension to
val (valid values are 2 or 3). This affects both the layer geometry
type, and feature geometries.
Best Regards, Eli
On Fri, May 24, 2013 at 9:23 AM, Pedro Costa <pedrocostaarma at sapo.pt> wrote:
> Hi guys,
> I'm trying  to make a script that converts 3d shapefiles to 2d.
> I'm using the loop 'for...do'' and this command:
> 'ogr2ogr -f "ESRI Shapefile" -nlt POINT 2d_points/$shp $shp'
> My problem is that i don't  know how to select only shapefiles of points,
> and next only polygons, and next only lines to put the right geometry in the
> command.
> For example, i have tried the '-where "OGR_GEOMETRY='Point'"'  like that:
> ogr2ogr -where "OGR_GEOMETRY='Point'" -f "ESRI Shapefile" -nlt POLYGON
> 2d_poligonos/$shp $shp
> But don't work because ogr converts shapefiles of polygons and lines into
> points!
> Can anyone tell me how i can select  only shapefiles of points in a folder
> with many shapefiles of many geometry types?
> Thanks
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
