[gdal-dev] Is using geometry in SQL inside VRT supported?
Fri May 24 09:46:48 PDT 2013
Jukka,
Agreed!  The SrcSQL directive in the VRT should accept a dialect option.
 I'll try to do that this afternoon as we are "sprinting" here at FOSS4G NA
and this would be a nice sized feature to add.
Best regards,
Frank
On Fri, May 24, 2013 at 8:39 AM, Jukka Rahkonen
<jukka.rahkonen at mmmtike.fi>wrote:
> Hi,
> This works with ogrinfo
> ogrinfo -ro cities.shp  -dialect SQLITE -sql "select GEOMETRY from cities"
> I tried to make a VRT file which would do the same
> <OGRVRTDataSource>
> <OGRVRTLayer name="cities">
> <SrcDataSource>cities.shp</SrcDataSource>
> <LayerSRS>WGS84</LayerSRS>
> <SrcSQL>SELECT GEOMETRY from cities</SrcSQL>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> Now ogrinfo does not find geometries
> ogrinfo cities.vrt
> INFO: Open of `cities.vrt'
>       using driver `VRT' successful.
> 1: citiesERROR 1: SQL Expression Parsing Error: syntax error
> ERROR 1: SQL statement failed, or returned no layer result:
> "SELECT GEOMETRY from cities"
> This exact use case is not at all interesting but there would be quite nice
> possibilities if Spatialite SQL queries could be fired from the VRT and all
> this would be supported for on-the-fly conversions
> http://www.gaia-gis.it/gaia-sins/spatialite-sql-4.0.0.html
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130524/51424db7/attachment-0001.html>
