[gdal-dev] Calculating polygon area
Federico Jurio federicojurio at suremptec.com.ar
Tue May 28 07:13:52 PDT 2013
Dear all, here I am with one question which I'm sure has such a simple
answer that I already feel embarassed in advance! Here goes anyway... I'm
trying to calculate the area length on a GeoTIFF file using GetArea()
method of OGRPolygon class and i'm not sure which is the unit that returns.
This is the information about the raster dataset
"GEOGCS[\"WGS 84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS
84\",6378137,298.2572235630016,AUTHORITY[\"EPSG\",\"7030\"]],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0],UNIT[\"degree\",0.0174532925199433],AUTHORITY[\"EPSG\",\"4326\"]]"
Thanks for your patience
Federico Jurio
SUR Emprendimientos Tecnológicos
Perú 345  Piso 5to Oficina "B" (C1067AAG)
Ciudad de Buenos Aires, Argentina
Tel. +54 (11) 4342-2976/84
www.suremptec.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130528/5a4609c8/attachment.html>
