[gdal-dev] gdal_translate produces tif with different colors as original
Andre Joost andre+joost at nurfuerspam.de
Thu Nov 7 07:54:32 PST 2013
Am 06.11.2013 21:32, schrieb Jukka Rahkonen:
> You're advised to preprocess your rasters with other
> tools, such as pct2rgb.py or gdal_translate -expand RGB to operate
> gdalbuildvrt on RGB rasters instead."
I proposed that, but have a look at the color palette of the VRT:
<http://gis.stackexchange.com/questions/76662/gdal-translate-produces-tif-with-different-colors-as-original>
Is it a fault of the source or the driver?
Greetings,
André Joost
