[gdal-dev] Building GDAL 1.9.2 for debugging
Hugo Benicio hbobenicio at gmail.com
Fri Nov 8 05:45:07 PST 2013
Nevermind, I got it
I was missing
nmake /f makefile.vc devinstall
On Fri, Nov 8, 2013 at 10:21 AM, Hugo Benicio <hbobenicio at gmail.com> wrote:
> I'm trying to compile GDAL 1.9.2 from source by myself using the DEBUG=1
> build.
> There is a flag on nmake.opt for VLD support:
> MSVC_VLD_DIR="C:\Program Files\Visual Leak Detector"
> although, if I try to use it, it give me strange error while building gdal.
> Anyways, I'm building gdal like this:
> nmake -f makefile.vc MSVC_VER=1500 DEBUG=1
> which seems to run nicely. Then I do:
> nmake -f makefile.vc MSVC_VER=1500 DEBUG=1 install
> Ok, everything seems good. I get the "gdal19.dll", "gdal_i.lib" and
> "gdal19.pdb"...
> but, where do I get the include files to use in my project?
> My build directory (GDAL_HOME =
> "C:\Users\Hugo\Downloads\gdal-1.9.2\build-debug")
> gives me only a "bin", "data" and "html" folders...
> Did the build really succeed? How can I get the include directory to build
> my project?
> Thanks in advance,
> Hugo Benício.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131108/12bcf3a6/attachment.html>
