[gdal-dev] writing XYZ file
denis cohen dcohen at iastate.edu
Sat Nov 9 11:39:50 PST 2013
Thanks for the script. It works fine except for the actual data (elevation
in my case, this is a DEM).
It does not write the correct values.
Merci
Denis
On Sat, Nov 9, 2013 at 8:02 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Le samedi 09 novembre 2013 10:46:20, denis cohen a écrit :
> > Hello,
> > I am a new user of gdal.
> > I used gdal_translate to convert a netcdf file to xyz:
> > gdal_translate -of XYZ file.nc file.xyz
> > However, the xyz file starts with the upperleft coordinate.
> > Is it possible to have it write the xyz file starting with the lower left
> > coordinate?
> Not directly although it wouldn't be complicated to add an option to do
> that.
> You can try the following GDAL Python script that will create an
> intermediary
> TIFF image that has both inverted georeferencing and imagery in a
> consistant
> way.
> python invert.py file.nc file_reserved.tif
> gdal_translate -of XYZ file_reversed.tif file.xyz
> ----- Begin of script invert.py ------
> # -*- coding: utf-8 -*-
> import sys
> from osgeo import gdal
> src_ds = gdal.Open(sys.argv[1])
> xsize = src_ds.RasterXSize
> ysize = src_ds.RasterYSize
> bandcount = src_ds.RasterCount
> out_drv = gdal.GetDriverByName('GTiff')
> out_ds = out_drv.Create(sys.argv[2], xsize, ysize, bandcount)
> out_ds.SetProjection(src_ds.GetProjectionRef())
> src_gt = src_ds.GetGeoTransform()
> out_gt = [ src_gt[i] for i in range(6) ]
> out_gt[3] = src_gt[3] + ysize * src_gt[5]
> out_gt[5] = -src_gt[5]
> out_ds.SetGeoTransform(out_gt)
> for j in range(src_ds.RasterYSize):
>     data = src_ds.ReadRaster(0, ysize - 1 - j, xsize, 1)
>     out_ds.WriteRaster(0, j, xsize, 1, data)
> out_ds = None
> src_ds = None
> ----- End of script ------
> Even
> Geospatial professional services
> http://even.rouault.free.fr/services.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131109/7ae22dc5/attachment.html>
