[gdal-dev] Getting SRID from MS SQL Server Spatial Table
Bob Cave bobc at bluemarblegeo.com
Wed Nov 13 12:13:16 PST 2013
Hello,
I am using the MS SQL Server driver (1.10.1) with
MSSQLSPATIAL_USE_GEOMETRY_COLUMNS=NO.  When I attempt to read a table, I
find that the driver does not identify the spatial reference the table is
using.  Is there a way to get the driver to query for the SRID?
When I use MSSQLSPATIAL_USE_GEOMETRY_COLUMNS=YES, then the SRID can be
identified.  This is fine for my test database, but I need to be able to
support databases that don't have a geometry_columns table.
Thanks,
Bob
View this message in context: http://osgeo-org.1560.x6.nabble.com/Getting-SRID-from-MS-SQL-Server-Spatial-Table-tp5089019.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
