[gdal-dev] Using/citing GDAL documentation
Eli Adam eadam at co.lincoln.or.us
Wed Nov 13 21:21:08 PST 2013
On Fri, Oct 18, 2013 at 6:13 PM, Jonathan Greenberg <jgrn at illinois.edu> wrote:
> GDALers:
> I'm working with a colleague on a new set of R wrappers for GDAL, and
> we are at the point where we are starting to document the functions.
> Our R interface is designed to be VERY close to the GDAL command line
> utilities (we use the same parameter names, for instance), so I was
> wondering if it would be ok to use almost word-for-word the GDAL
> documentation of each of the parameters in our package's man files
> (this would save us an inordinate amount of time paraphrasing the docs
> for all of those functions).  If this is ok, how should I cite the
> documentation properly?
I can't answer about reuse of the documentation, but citation is
probably covered here,
http://trac.osgeo.org/gdal/wiki/FAQGeneral#HowdoIciteGDAL
Hopefully someone else will more directly answer your questions (my
uninformed opinion is that reuse is probably fine).
Best Regards, Eli
> Cheers!  Incidentally, the package is up on R-forge:
> https://r-forge.r-project.org/projects/gdalutils/
> --j
> Jonathan A. Greenberg, PhD
> Assistant Professor
> Global Environmental Analysis and Remote Sensing (GEARS) Laboratory
> Department of Geography and Geographic Information Science
> University of Illinois at Urbana-Champaign
> 259 Computing Applications Building, MC-150
> 605 East Springfield Avenue
> Champaign, IL  61820-6371
> Phone: 217-300-1924
> http://www.geog.illinois.edu/~jgrn/
> AIM: jgrn307, MSN: jgrn307 at hotmail.com, Gchat: jgrn307, Skype: jgrn3007
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
