[gdal-dev] Using/citing GDAL documentation
Jonathan Greenberg jgrn at illinois.edu
Sat Nov 16 13:51:50 PST 2013
Hi Nick:
My package (gdalUtils) are just straight-wrappers for the GDAL Utilities (
http://www.gdal.org/gdal_utilities.html) -- I've got most of the non-python
ones finished.  rgdal contain low-level bindings to GDAL and Python (
http://cran.r-project.org/web/packages/rgdal/index.html), but are missing
quite a few functions that the GDAL Utilities contain.  On top of that,
rgdal uses a compiled version of some of the GDAL libraries that is missing
quite a bit of functionality, particularly on Windows boxes -- most
notably, HDF4/5 support.  My package does not contain a GDAL install, it
searches for one that a user installed themselves (typically via
OSGeo4W/QGIS), so provides more flexibility in variations in GDAL
installations.
rgdal and gdalUtils are complementary packages, mind you.  rgdal is used
quite a bit by other packages for providing various raster functionality.
 I'm simply filling in some of the gaps in rgdal's capabilities.
--j
On Thu, Nov 14, 2013 at 7:59 AM, Nick Ves <vesnikos at gmail.com> wrote:
> sounds really cool.
> One question though: Whats the difference between gdalUtils and rgdal?
> On Sat, Oct 19, 2013 at 4:13 AM, Jonathan Greenberg <jgrn at illinois.edu>
> wrote:
> > GDALers:
> > I'm working with a colleague on a new set of R wrappers for GDAL, and
> > we are at the point where we are starting to document the functions.
> > Our R interface is designed to be VERY close to the GDAL command line
> > utilities (we use the same parameter names, for instance), so I was
> > wondering if it would be ok to use almost word-for-word the GDAL
> > documentation of each of the parameters in our package's man files
> > (this would save us an inordinate amount of time paraphrasing the docs
> > for all of those functions).  If this is ok, how should I cite the
> > documentation properly?
> > Cheers!  Incidentally, the package is up on R-forge:
> > https://r-forge.r-project.org/projects/gdalutils/
> > --j
> > Jonathan A. Greenberg, PhD
> > Assistant Professor
> > Global Environmental Analysis and Remote Sensing (GEARS) Laboratory
> > Department of Geography and Geographic Information Science
> > University of Illinois at Urbana-Champaign
> > 259 Computing Applications Building, MC-150
> > 605 East Springfield Avenue
> > Champaign, IL  61820-6371
> > Phone: 217-300-1924
> > http://www.geog.illinois.edu/~jgrn/
> > AIM: jgrn307, MSN: jgrn307 at hotmail.com, Gchat: jgrn307, Skype: jgrn3007
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
Assistant Professor
Phone: 217-300-1924
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131116/367af77e/attachment.html>
