[gdal-dev] Generated KML incorrectly formated and image reflected in X axis
JSz james at agritech.co.uk
Mon Nov 18 13:33:34 PST 2013
Perfect, that solved the projection issue.
Have you any ideas why the KMZ file isn't able to open in google earth but
if I remove the individual parts ( 0.kml and 0.png ) and open all is ok?
Alternativly is there a way to just generate the KML file directly rather
than with :
gdal_translate.exe -of KMLSUPEROVERLAY MY_TIFF_File.tiff Output.kmz -co
FORMAT=PNG
J
View this message in context: http://osgeo-org.1560.x6.nabble.com/Generated-KML-incorrectly-formated-and-image-reflected-in-X-axis-tp5089715p5089752.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
