[gdal-dev] Can GDAL access ARCGIS REST services?
Moskovitz, Bob@DOC Bob.Moskovitz at conservation.ca.gov
Wed Nov 20 11:28:09 PST 2013
That's too bad :(  Here is another one that doesn't work even though it says it is a "MapServer":  http://atlas.resources.ca.gov/ArcGIS/rest/services/Base_Maps/NAIP2012_Index/MapServer .
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: Wednesday, November 20, 2013 11:22 AM
To: gdal-dev at lists.osgeo.org
Cc: Moskovitz, Bob at DOC
Subject: Re: [gdal-dev] Can GDAL access ARCGIS REST services?
Le mercredi 20 novembre 2013 19:58:29, Moskovitz, Bob at DOC a écrit :
> Hello all,
> At one time, I was able to view NAIP imagery using WMS, but it appears that
> I can only access it using ARCGIS REST services.   According to
> http://www.northrivergeographic.com/qgis-adding-an-arcgis-rest-service
> , I tried something like this:
> C:\>gdal_translate --debug on
> "http://gis.apfo.usda.gov/arcgis/rest/services/NAIP/California_2012_1m
> _NC/ ImageServer?f=json&pretty=true" c:\temp\NAIP2012.xml -of WMS
> HTTP:
> Fetch(http://gis.apfo.usda.gov/arcgis/rest/services/NAIP/California_20
> 12_1
> m_NC/ImageServer?f=json&pretty=true) ERROR 4:
> `/vsimem/http_1/file.dat' not recognised as a supported file format.
> ERROR 4: `/tmp/file.dat' not recognised as a supported file format.
> GDALOpen failed - 4
> Anyone have any suggestions on how to access this web service?
The WMS driver only understands documents produced by the "MapServer" ArcGIS service/protocol, not "ImageServer"
> Thanks!
> Robert Moskovitz
> California Geological Survey
> Seismic Hazards Zonation Program
> CONFIDENTIALITY NOTICE: This communication is intended only for the
> use of the individual or entity to which it is addressed. This message
> contains information from the State of California, California
> Geological Survey, which may be privileged, confidential and exempt
> from disclosure under applicable law, including the Electronic
> Communications Privacy Act. If the reader of this communication is not
> the intended recipient, you are hereby notified that any
> dissemination, distribution, or copying of this communication is strictly prohibited.
Geospatial professional services
http://even.rouault.free.fr/services.html
