[gdal-dev] Gdalinfo does not print into file on Windows
Antonio Falciano afalciano at yahoo.it
Fri Nov 22 02:15:23 PST 2013
Il 18/09/2013 01:34, lpinner ha scritto:
> Disabling the ECW plugin also enables setting a non-zero exit code
> (http://trac.osgeo.org/gdal/ticket/4830)
Hi all,
it seems that this issue disappears updating to ECW 5.0 SDK, as Tamas
Szekeres suggests in this ticket [1]. I've discovered it doing some little
tests on GSE [2]. Can anyone confirm this?
Cheers,
Antonio
[1] https://github.com/gisinternals/buildsystem/issues/36
[2]
http://gis.stackexchange.com/questions/78304/gdalinfo-image-tifstats-txt-returns-empty-text-file-windows-7-64-bit
Antonio Falciano
http://www.linkedin.com/in/antoniofalciano
