[gdal-dev] WRF NetCDF import
Etienne Tourigny etourigny.dev at gmail.com
Sun Nov 24 08:20:24 PST 2013
The "georeferencing info" you refer to is non-standard, and GDAL cannot use
that. It (and presumably the grass provider, although I don't know) use the
CF standard for encoding lat/lon information. what is the output of
gdalinfo NETCDF:test_full.nc:HGT
I don't know how the grass provider deals with subdatasets, but if you open
the file in qgis (using the gdal provider, it will sllow you to select the
subdataset you want).
You could also extract the variable with another tool like cdo or nco.
Etienne
On Sat, Nov 23, 2013 at 7:47 PM, Lee Eddington <lee.w.eddington at gmail.com>wrote:
> I'm trying to use r.in.gdal in GRASS GIS to import Weather Research &
> Forecasting (WRF) model NetCDF output.  There have been some tips provided
> by the GRASS users list, but none have worked for me.  I can import the
> data as a simple x,y array with no georeferencing, but information about
> georeferencing is in the file as other programs read, georeference and
> display the file correctly.
> gdalinfo produces the following:
> lees-mbp:full Lee$ gdalinfo test_full.nc
> Warning 1: No UNIDATA NC_GLOBAL:Conventions attribute
> Driver: netCDF/Network Common Data Format
> Files: test_full.nc
> Size is 512, 512
> Coordinate System is `'
> Metadata:
>   NC_GLOBAL#BL_PBL_PHYSICS=1
>   NC_GLOBAL#BOTTOM-TOP_GRID_DIMENSION=28
>   NC_GLOBAL#BOTTOM-TOP_PATCH_END_STAG=28
>   NC_GLOBAL#BOTTOM-TOP_PATCH_END_UNSTAG=27
>   NC_GLOBAL#BOTTOM-TOP_PATCH_START_STAG=1
>   NC_GLOBAL#BOTTOM-TOP_PATCH_START_UNSTAG=1
>   NC_GLOBAL#BUCKET_J=-1
>   NC_GLOBAL#BUCKET_MM=-1
>   NC_GLOBAL#CEN_LAT=-8.4095154
>   NC_GLOBAL#CEN_LON=115.02
>   NC_GLOBAL#CU_PHYSICS=0
>   NC_GLOBAL#DAMP_OPT=0
>   NC_GLOBAL#DAMPCOEF=0.2
>   NC_GLOBAL#DFI_OPT=0
>   NC_GLOBAL#DIFF_6TH_FACTOR=0.12
>   NC_GLOBAL#DIFF_6TH_OPT=0
>   NC_GLOBAL#DIFF_OPT=1
>   NC_GLOBAL#DT=16.666666
>   NC_GLOBAL#DX=3000
>   NC_GLOBAL#DY=3000
>   NC_GLOBAL#FEEDBACK=0
>   NC_GLOBAL#GFDDA_END_H=0
>   NC_GLOBAL#GFDDA_INTERVAL_M=0
>   NC_GLOBAL#GMT=12
>   NC_GLOBAL#GRID_FDDA=0
>   NC_GLOBAL#GRID_ID=3
>   NC_GLOBAL#GRID_SFDDA=0
>   NC_GLOBAL#GRIDTYPE=C
>   NC_GLOBAL#HYPSOMETRIC_OPT=2
>   NC_GLOBAL#I_PARENT_START=34
>   NC_GLOBAL#ISFTCFLX=0
>   NC_GLOBAL#ISHALLOW=0
>   NC_GLOBAL#ISICE=24
>   NC_GLOBAL#ISLAKE=-1
>   NC_GLOBAL#ISOILWATER=14
>   NC_GLOBAL#ISURBAN=1
>   NC_GLOBAL#ISWATER=16
>   NC_GLOBAL#J_PARENT_START=34
>   NC_GLOBAL#JULDAY=324
>   NC_GLOBAL#JULYR=2013
>   NC_GLOBAL#KHDIF=0
>   NC_GLOBAL#KM_OPT=4
>   NC_GLOBAL#KVDIF=0
>   NC_GLOBAL#MAP_PROJ=3
>   NC_GLOBAL#MFSHCONV=0
>   NC_GLOBAL#MMINLU=USGS
>   NC_GLOBAL#MOAD_CEN_LAT=-8.4095078
>   NC_GLOBAL#MOIST_ADV_OPT=1
>   NC_GLOBAL#MP_PHYSICS=3
>   NC_GLOBAL#NUM_LAND_CAT=24
>   NC_GLOBAL#OBS_NUDGE_OPT=0
>   NC_GLOBAL#OMLCALL=0
>   NC_GLOBAL#PARENT_GRID_RATIO=3
>   NC_GLOBAL#PARENT_ID=2
>   NC_GLOBAL#POLE_LAT=90
>   NC_GLOBAL#POLE_LON=0
>   NC_GLOBAL#PREC_ACC_DT=0
>   NC_GLOBAL#RA_LW_PHYSICS=1
>   NC_GLOBAL#RA_SW_PHYSICS=1
>   NC_GLOBAL#SCALAR_ADV_OPT=1
>   NC_GLOBAL#SF_SFCLAY_PHYSICS=1
>   NC_GLOBAL#SF_SURFACE_PHYSICS=2
>   NC_GLOBAL#SF_URBAN_PHYSICS=0
>   NC_GLOBAL#SGFDDA_END_H=0
>   NC_GLOBAL#SGFDDA_INTERVAL_M=0
>   NC_GLOBAL#SHCU_PHYSICS=0
>   NC_GLOBAL#SIMULATION_START_DATE=2013-11-20_12:00:00
>   NC_GLOBAL#SMOOTH_OPTION=0
>   NC_GLOBAL#SOUTH-NORTH_GRID_DIMENSION=154
>   NC_GLOBAL#SOUTH-NORTH_PATCH_END_STAG=154
>   NC_GLOBAL#SOUTH-NORTH_PATCH_END_UNSTAG=153
>   NC_GLOBAL#SOUTH-NORTH_PATCH_START_STAG=1
>   NC_GLOBAL#SOUTH-NORTH_PATCH_START_UNSTAG=1
>   NC_GLOBAL#SST_UPDATE=0
>   NC_GLOBAL#STAND_LON=115.02
>   NC_GLOBAL#START_DATE=2013-11-20_12:00:00
>   NC_GLOBAL#SURFACE_INPUT_SOURCE=1
>   NC_GLOBAL#SWRAD_SCAT=1
>   NC_GLOBAL#TITLE= OUTPUT FROM WRF V3.4 MODEL
>   NC_GLOBAL#TKE_ADV_OPT=1
>   NC_GLOBAL#TRUELAT1=-8.4095001
>   NC_GLOBAL#TRUELAT2=0
>   NC_GLOBAL#W_DAMPING=0
>   NC_GLOBAL#WEST-EAST_GRID_DIMENSION=199
>   NC_GLOBAL#WEST-EAST_PATCH_END_STAG=199
>   NC_GLOBAL#WEST-EAST_PATCH_END_UNSTAG=198
>   NC_GLOBAL#WEST-EAST_PATCH_START_STAG=1
>   NC_GLOBAL#WEST-EAST_PATCH_START_UNSTAG=1
> Subdatasets:
>   SUBDATASET_1_NAME=NETCDF:"test_full.nc":Times
>   SUBDATASET_1_DESC=[1x19] Times (8-bit character)
>   SUBDATASET_2_NAME=NETCDF:"test_full.nc":LU_INDEX
>   SUBDATASET_2_DESC=[1x153x198] LU_INDEX (32-bit floating-point)
> (more SUBDATASETs)
>   SUBDATASET_106_NAME=NETCDF:"test_full.nc":LANDMASK
>   SUBDATASET_106_DESC=[1x153x198] LANDMASK (32-bit floating-point)
>   SUBDATASET_107_NAME=NETCDF:"test_full.nc":SST
>   SUBDATASET_107_DESC=[1x153x198] SST (32-bit floating-point)
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0,  512.0)
> Upper Right (  512.0,    0.0)
> Lower Right (  512.0,  512.0)
> Center      (  256.0,  256.0)
> My first question is why am I getting the following warning?:
> Next, I see what appears is georeferencing info in the following lines:
>   NC_GLOBAL#MAP_PROJ=3 (Mercator)
> but obviously this is not being interpreted or used.
> Trying to use gdalwarp:
> lees-mbp:full Lee$ gdalwarp NETCDF:test_full.nc:HGT test_full_HGT.tif
> ERROR 1: Unable to compute a transformation between pixel/line
> and georeferenced coordinates for NETCDF:test_full.nc:HGT.
> There is no affine transformation and no GCPs.
> Can anyone explain what I need to do?
> Thanks,
> Lee
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131124/11a770c2/attachment-0001.html>
