[gdal-dev] Large shapefile issues
CARMAN, Darren Darren.Carman at astrium.eads.net
Mon Nov 25 02:42:23 PST 2013
Hi List
I notice on the OGR formats page for ESRI Shapefile the following is
Size Issues
Geometry: The Shapefile format explicitly uses 32bit offsets and so
cannot go over 8GB (it actually uses 32bit offsets to 16bit words).
Hence, it is is not recommended to use a file size over 4GB.
Attributes: The dbf format does not have any offsets in it, so it can be
arbitrarily large.
Yet on the ESRI website:
Geometry limitations
There is a 2 GB size limit for any shapefile component file, which
translates to a maximum of roughly 70 million point features. The actual
number of line or polygon features you can store in a shapefile depends
on the number of vertices in each line or polygon (a vertex is
equivalent to a point).
I assume the OGR web page is wrong, or has a different meaning outside
of ESRI S/W use.
I notice that the PostGIS utility pgsql2shp stops processing with an
error once the dbf file goes over 2GB. Is there any way to get ogr2ogr
to do this?
Ideally, something I can't find a lot of information about online, is
there a way to get ogr2ogr to start writing to a new shapefile at a
certain processing point (number of objects or file size)?
Alternatively, assuming the OGR website text is correct for files it
creates, is there any utility that could be used to split the created
shapefile files into ones with a size less than 2GB?
Thanks in advance
Darren
 Darren Carman
Senior Software Engineer
GEO-Information Services
Astrium Services
Tel +44 (0)1252 362138
http://www.astrium-geo.com <http://www.infoterra.co.uk>
Infoterra Ltd. Is part of the Astrium GEO-Information Services Division and a wholly owned subsidiary of Astrium, Europe's leading space systems and services specialist.
Disclaimer. The information contained in this e-mail and its attachments are confidential and intended only for the use of the named addressee(s). If you are not the intended addressee, please do not read, copy, use or disclose this message or its attachments. If you have received this message in error, please notify the sender immediately and delete or destroy all copies of this message and attachments in all media. Any views or opinions expressed are solely those of the author and do not necessarily represent those of Infoterra Ltd and shall not form part of any binding agreement.
Infoterra Limited a company registered in England under number 2359955 and having its registered office at Europa House, Southwood Crescent, Farnborough, GU14 0NL. VAT number GB 476 0468 27.
P Before printing, think about the environment
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131125/4d5e8487/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131125/4d5e8487/attachment.png>
