[gdal-dev] Slice Large GeoTiff into 1 Degree Tiles
Metzen osgeo at gzmarketing.com
Mon Nov 25 13:38:45 PST 2013
I have a bunch of large GeoTiff files (1.4GB, 4 latitude degrees x 8
longitude degrees).
I need to slice each one up into 1 degree lat x 1 degree long tiles (with
just a little bit of overage in each).
Here is the gdalinfo output for one of the GeoTiff files:
Driver: GTiff/GeoTIFF
Files: index.tif
Size is 38401, 19201
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433],
    AUTHORITY["EPSG","4326"]]
Origin = (-112.000104166666674,56.000104166666667)
Pixel Size = (0.000208333333333,-0.000208333333333)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (-112.0001042,  56.0001042) (112d 0' 0.38"W, 56d 0' 0.37"N)
Lower Left  (-112.0001042,  51.9998958) (112d 0' 0.38"W, 51d59'59.62"N)
Upper Right (-103.9998958,  56.0001042) (103d59'59.62"W, 56d 0' 0.37"N)
Lower Right (-103.9998958,  51.9998958) (103d59'59.62"W, 51d59'59.62"N)
Center      (-108.0000000,  54.0000000) (108d 0' 0.00"W, 54d 0' 0.00"N)
Band 1 Block=38401x1 Type=Int16, ColorInterp=Gray
  NoData Value=-32767
I want everything to be the same except the size. So each one needs to be
sliced into 32 tiles, each 1 degree x 1 degree.
For instance one would cover:
-112.0001042, 56.0001042 to -110.9998958, 54.9998958 (essentially -112, 56
to -111, 55).
I see utilities like gdal_retile.py and gdal_grid, but I'm not making
progress.
Is there a gdal tool that can do what I need?   If so, which one(s), and can
you share an example command?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Slice-Large-GeoTiff-into-1-Degree-Tiles-tp5091122.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
