[gdal-dev] How to get GDAL
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Wed Nov 27 08:02:53 PST 2013
Hi List,
I'm bringing this one over from the GeoServer-Users list. Basically I can't
for the life of me get a good install of GDAL for Windows where everything
*just works*.
To date I've tried:
http://gisinternals.com/SDK/P
 - But there are far too many options and I can never be sure I'm getting
the right thing (the page assumes a significant level of knowledge about
what package is what). In the end I just go with -
http://gisinternals.com/SDK/PackageList.aspx?file=release-1600-x64-gdal-1-10-mapserver-6-4.zip
 - From there I've tried both the msi (plus python bindings extra) and the
zip "Compiled binaries in a single .zip package"- both work for the
pure-GDAL stuff (gdalinfo) but none of the python scripts works (i.e.
gdal_merge.py).
I found FWTools - http://fwtools.maptools.org/ - except that it seems to be
an outdated version of GDAL so I'm hitting some GDAL bugs there that I
think are since fixed.
The QGIS version comes with all manner of environmental variable issues
that stop it from working stand-alone for me.
I think I may have tried the version that comes with FME too, but similar
issues.
So in short, where can I go to find a pre-compiled (Windows, ideally 64bit)
version of GDAL that Just Works?
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131127/539e53e8/attachment.html>
