[gdal-dev] How to get GDAL
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Wed Nov 27 08:30:05 PST 2013
Wow, that actually worked!
/me is pleasantly surprised. :-)
Thanks!
On 27 November 2013 16:15, Mateusz Loskot <mateusz at loskot.net> wrote:
> On 27 November 2013 16:02, Jonathan Moules
> <jonathanmoules at warwickshire.gov.uk> wrote:
> > So in short, where can I go to find a pre-compiled (Windows, ideally
> 64bit)
> > version of GDAL that Just Works?
> http://trac.osgeo.org/osgeo4w/
> Best regards,
> Mateusz  Loskot, http://mateusz.loskot.net
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131127/edf57ecb/attachment.html>
