[gdal-dev] How to get GDAL
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Thu Nov 28 03:34:25 PST 2013
>    - From there I've tried both the msi (plus python bindings extra) and
>> the
>> zip "Compiled binaries in a single .zip package"- both work for the
>> pure-GDAL stuff (gdalinfo) but none of the python scripts works (i.e.
>> gdal_merge.py).
> I prefer the zip version, expand it to a folder of my choice, and run the
> SDKshell.bat. In the command window I can do the things I want to do in
> GDAL, without any interfering of other programms, even not from QGIS.
> Inside the shell, all varaibles are set correctly, and therefore all python
> modules run too.
> And it is no problem installing an experimental new GDAL version and
> keeping the old one in parallel.
That would be my preferred option, but as noted, the python stuff doesn't
work. I was getting a python error whenever I tried to run them.
Fortunately the OSGeo4W version works fine.
Cheers,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131128/699a3f94/attachment.html>
