[gdal-dev] SetColorInterpretation() for a GeoTiff using GDAL not working
philwilkes phil.wilkes at rmit.edu.au
Fri Nov 29 02:25:18 PST 2013
I have also posted this on http://gis.stackexchange.com/ but had no joy so
thought I'd try my luck here!
I have a single band image which I would like to copy to a 3 bands of a new
image and set the ColorInterpretation to red, green and blue respectively. I
have tried two approaches, one using the GTiff driver, explained below, and
the other using the VRT driver.
My code is;
from osgeo import gdal
import os
IM = "path/to/image.tif" # single band image
### read image ###
ds = gdal.Open(IM)
X = ds.RasterXSize
Y = ds.RasterYSize
band = ds.GetRasterBand(1).ReadAsArray()
### write to 3 bands ###
driver = gdal.GetDriverByName("GTiff")
outPath = os.path.join(os.path.split(IM)[0], "test_image.tif")
outIM = driver.Create(outPath, X, Y, 3, gdal.GDT_Int16)
for i in range(1, 4):
    outIM.GetRasterBand(i).SetRasterColorInterpretation(2 + i)
    outIM.GetRasterBand(i).WriteArray(band)
    print outIM.GetRasterBand(i).GetRasterColorInterpretation()
outIM = None
The output is:
1
0
0
I have also tried using the SetColorInterpretation().
My question is, how do I set the ColorInterpretation metatag using the GTiff
driver?
View this message in context: http://osgeo-org.1560.x6.nabble.com/SetColorInterpretation-for-a-GeoTiff-using-GDAL-not-working-tp5091839.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
