[gdal-dev] Write dataset to web output
Jean-Claude Repetto jrepetto at free.fr
Tue Oct 1 09:01:15 PDT 2013
Le 01/10/2013 16:21, Guillaume Sueur a écrit :
> My use case is weird as I am using GDAL to reproject a WMS source which
> doesn't offer web mercator (French Cadastral Parcels WMS) and needs some
> computation on the URL (city code, CRS depending on location).
> If I understand your solution, I can't directly output my datasource to
> the webserver, I need to write it on disk first ?
Hello,
May be you should have a look at MapProxy, which is able to reproject
on-the-fly a WMS service.
Jean-Claude
