[gdal-dev] sqlite dialect and MySQL spatial input
Even Rouault even.rouault at mines-paris.org
Tue Oct 1 11:29:14 PDT 2013
Le mardi 01 octobre 2013 08:58:22, Jukka Rahkonen a écrit :
> Even Rouault <even.rouault <at> mines-paris.org> writes:
> > I've just pushed in trunk a change to make SQLITE dialect available to
> > all
> OGR
> > drivers that have a specialized ExecuteSQL() implementation.
> Hi,
> Is this a correct interpretation:
> - The default SQL dialect is "OGR SQL", except for databases when the
> default is to use the native SQL dialect of the RDBMS
> - The default dialect can be overridden by the -dialect parameter, which
> can take values "OGR SQL" or "SQLITE" and after your change this works for
> all drivers in a similar way.
Yes. Just to crrect : the string is OGRSQL (no space)
> If this is right I will have a look at the documentation and see if there
> is something to improve. At least I would make a little addition into
> http://www.gdal.org/ogr2ogr.html
> Now there reads
> -dialect dialect:
>     SQL dialect. In some cases can be used to use (unoptimized) OGR SQL
> instead of the native SQL of an RDBMS by passing OGRSQL. Starting with GDAL
> 1.10, the "SQLITE" dialect can also be used with any datasource.
> It would be good to give the alternatives and a hint about how to give OGR
> SQL so that the space character will not cause trouble as
> -dialect dialect:
>     SQL dialect. Can take values "OGR SQL" or "SQLITE".
Adding quote would be indeed good to avoid the confusion with space/nospace.
Want to give a crack at it ?
> Should we do something also for the statement "Starting with GDAL 1.10, the
> "SQLITE" dialect can also be used with any datasource" which is totally
> true with databases only after your commit
> http://trac.osgeo.org/gdal/changeset/26506
Not sure how to render the dynamics of before and after r26506. I would
perhaps just keep it as it is currently to avoid confusion. Using SQLITE
dialect with a RDBMS driver is kind of unusual use case (which was the thing
that was finxed with r26506).
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Geospatial professional services
http://even.rouault.free.fr/services.html
