[gdal-dev] Kernel resource leak -- Windows
Even Rouault even.rouault at mines-paris.org
Tue Oct 1 12:08:44 PDT 2013
Le lundi 30 septembre 2013 00:59:33, Joaquim Luis a écrit :
> Hi,
> I can make a ticket with this but before, let me just report it here.
> - Win 64 bits GDAL build
> While playing with an Intel analysis tool to chase GMT memory leaks I
> got two complains respecting GDAL.
> P1: Error: Kernel resource leak
>   P1.55: Kernel resource leak: New
>    c:\programs\gdaltrunk\gdal\port\cpl_multiproc.cpp(626): Error X63:
> Critical section creation site: Function CPLCreateMutex: Module
> C:\progs_cygw\GMTdev\gmt5\trunk\WIN64\bin\gdal_w64.dll
>    Code snippet:
>     624      if( pcs )
>     625      {
>  >626        InitializeCriticalSectionAndSpinCount(pcs, 4000);
>     627        EnterCriticalSection(pcs);
>     628      }
> The MS Help says that this can be solved with a call
> to'FindCloseChangeNotification'
MSDN doesn't mention FindCloseChangeNotification as a valid function to call
related to the use of InitializeCriticalSectionAndSpinCount.
Is it really a repeated memory leak (something that will be leaked each time
you call CPLCreateMutex() - with correctly paired CPLDestroyMutex() - and that
will end up exhausting memory / kernel ressources ) or just a one time memory
leak (something that a tool like valgrind would report as 'still reachable' at
the end of the process) due to one of the main "static" GDAL mutex not being
freed ?
Geospatial professional services
http://even.rouault.free.fr/services.html
