[gdal-dev] sqlite dialect and MySQL spatial input
aborruso aborruso at gmail.com
Wed Oct 2 01:13:23 PDT 2013
firts of all thank you for your work. It is always very nice to see how a
great open source community works.
Even Rouault wrote
> Using SQLITE dialect with a RDBMS driver is kind of unusual use case
> (which was the thing that was finxed with r26506).
I want to add a detail, but I do not know whether it is useful. I have
discovered this over-override
trick, because I needed to use real spatial SQL functions, not the limited
MBR functions of MySQL spatial.
With this trick I have solved.
Best regards,
Andrea
View this message in context: http://osgeo-org.1560.x6.nabble.com/sqlite-dialect-and-MySQL-spatial-input-tp5080909p5081365.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
