[gdal-dev] sqlite dialect and MySQL spatial input
aborruso aborruso at gmail.com
Wed Oct 2 01:30:26 PDT 2013
Hi Even,
Even Rouault wrote
> Wouldn't Area() as described in
> http://dev.mysql.com/doc/refman/5.0/en/geometry-property-
> functions.html#function_area do the job ?
you are right, but I have used Area() in my post to make a simple example.
I'm talking about functions like "Contains". In MySQL documentation you
read:
"Currently, MySQL does not implement these functions according to the
specification. Those that are implemented return the same result as the
corresponding MBR-based functions."
Then I have used something like "ogrinfo test.vrt -dialect sqlite -sql
“SELECT *FROM polygons as g1, points as g2 WHERE
Contains(g1.geometry,g2.geometry) = 1"
Thank you
View this message in context: http://osgeo-org.1560.x6.nabble.com/sqlite-dialect-and-MySQL-spatial-input-tp5080909p5081369.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
