[gdal-dev] sqlite dialect and MySQL spatial input
aborruso aborruso at gmail.com
Thu Oct 3 02:55:09 PDT 2013
Ciao Jukka,
Rahkonen Jukka wrote
> It could be good to mention that since GDAL version r26506 in trunk and
> with
> the future GDAL releases beginning from 1.11 (or 2.0) users do not need to
> do this in a tricky way with VRT but it is enough to just use -dialect
> SQLITE. People will find your blog with search engines also in the future.
you are right. I made it.
Thank you again
View this message in context: http://osgeo-org.1560.x6.nabble.com/sqlite-dialect-and-MySQL-spatial-input-tp5080909p5081575.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
