[gdal-dev] EPSG 8.2 Upgrade
Paul Meems bontepaarden at gmail.com
Thu Oct 3 03:53:28 PDT 2013
I'm not sure if this is the correct place to report this. If not please let
me know.
I'm having trouble compiling the trunk version of PROJ.4 with the updated
EPSG 8.2 database definitions.
I'm running Win7 and use VS2008.
I'm getting these errors and warnings:
Warning  1    Command line warning D9002 : ignoring unknown option '/Op'
cl
Warning  2    warning C4129: 'P' : unrecognized character escape
sequence    pj_open_lib.c
Warning  3    warning C4129: 'S' : unrecognized character escape
Error    4    error C2143: syntax error : missing ';' before 'type'
PJ_healpix.c
Error    5    error C2143: syntax error : missing ';' before 'type'
PJ_healpix.c
Error    6    error C2065: 'xc' : undeclared identifier    PJ_healpix.c
Error    7    error C2065: 'xc' : undeclared identifier    PJ_healpix.c
Error    8    error C2065: 'tau' : undeclared identifier    PJ_healpix.c
Error    9    error C2065: 'tau' : undeclared identifier    PJ_healpix.c
When I use the zipped source code for v4.8.0 I don't have these problems.
Can anybody assist?
Thanks,
Paul
2013/10/2 Frank Warmerdam <warmerdam at pobox.com>
> Folks,
> I have upgraded libgeotiff, GDAL and PROJ.4 trunk's with
> the EPSG 8.2 database definitions.   I have come to the
> conclusion that the EPSG Postgresql .sql files are distributed
> in WIN1252 encoding, not LATIN1, and so some special
> characters - mostly in comments - should be translated better.
> Let me know if you see problems or have questions.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Software Developer
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131003/2ac7186f/attachment.html>
