[gdal-dev] OGR datasources
Olivier BARTHELEMY barthelemy at geovariances.com
Thu Oct 3 09:03:48 PDT 2013
Can't you get that by looking at the lines of `gdalinfo --formats`that
contain rw+ access?
2013/10/3 Jaak Laineste (Nutiteq) <jaak at nutiteq.com>
> Does anyone has a list of OGR datasources which support update ?
> The tables and test methods have "create" capability, but not update. And
> it turns out that there are datasources (e.g. MapInfo) which allow create,
> but does not allow editing of existing data (opening in write mode).
> Actually the only datasource what I found where it works fine was
> Shapefile, but I did not try many
> I'm using it in Android context, so "big" datasources with libraries
> (PostGIS, ESRI etc) where it probably works are not really usable there.
> Built-in simple file datasources are more interesting, but a general way to
> have a list would be best.
> Jaak
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Olivier BARTHELEMY
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131003/d01e0b17/attachment.html>
