[gdal-dev] Compile GDAL with GEOS, strange GEOS_CFLAGS
Paul Meems bontepaarden at gmail.com
Fri Oct 4 01:21:13 PDT 2013
Hi all,
As mentioned before I'm trying to upgrade all supporting libraries we are
using with MapWinGIS.
I'm also documenting all steps so others can do this as well.
The build seems to be OK but I'm wondering about this part:
GEOS_CFLAGS = -I$(GEOS_DIR)/capi -I$(GEOS_DIR)/source/headers -DHAVE_GEOS
I have no $(GEOS_DIR)/source folder. I'm using GEOS v3.4.2.
I noticed in the past we used the same flags and the folder didn't exists
either, so most likely it is nothing to worry about ;)
But I want to make sure. Should I change it, delete it or leave it?
I'm running Win7 and compile using nmake in a VS2008 command prompt.
Thanks,
Paul
 *Paul Meems *
Release manager, configuration manager
and forum moderator of MapWindow GIS.
www.mapwindow.org
Owner of MapWindow.nl - Support for
Dutch speaking users.
www.mapwindow.nl
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131004/bca31ca3/attachment.html>
