[gdal-dev] Compile GDAL with GEOS, strange GEOS_CFLAGS
SIMON Nicolas nicolas.simon at spw.wallonie.be
Fri Oct 4 04:52:46 PDT 2013
Hi Paul,
  If it can help, here is my config
GEOS_CFLAGS = -I$(GEOS_DIR)/capi -I$(GEOS_DIR)/include -DHAVE_GEOS
GEOS_LIB     = $(GEOS_DIR)/src/geos_c_i.lib
Regards,
Nicolas
De : gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] De la part de Paul Meems
Envoyé : vendredi 4 octobre 2013 10:21
À : gdal-dev at lists.osgeo.org
Objet : [gdal-dev] Compile GDAL with GEOS, strange GEOS_CFLAGS
Hi all,
As mentioned before I'm trying to upgrade all supporting libraries we are using with MapWinGIS.
I'm also documenting all steps so others can do this as well.
The build seems to be OK but I'm wondering about this part:
GEOS_CFLAGS = -I$(GEOS_DIR)/capi -I$(GEOS_DIR)/source/headers -DHAVE_GEOS
I have no $(GEOS_DIR)/source folder. I'm using GEOS v3.4.2.
I noticed in the past we used the same flags and the folder didn't exists either, so most likely it is nothing to worry about ;)
But I want to make sure. Should I change it, delete it or leave it?
I'm running Win7 and compile using nmake in a VS2008 command prompt.
Thanks,
Paul
[http://www.bontepaarden.nl/bontepaarden/images/newButton.png]Paul Meems
Release manager, configuration manager
and forum moderator of MapWindow GIS.
www.mapwindow.org<http://www.mapwindow.org/>
Owner of MapWindow.nl - Support for
Dutch speaking users.
www.mapwindow.nl<http://www.mapwindow.nl/>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131004/9c0f28e3/attachment.html>
