[gdal-dev] ogrinfo: how retrieve the extent of a single geometry
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Sat Oct 5 12:20:03 PDT 2013
Andre Joost <andre+joost <at> nurfuerspam.de> writes:
> Am 05.10.2013 08:11, schrieb Andrea Peri:
> > Hi all,
> > I need to retrieve the extent of a single geometry using ogrinfo.
> > I try to use this sintax:
> > ogrinfo -al -so filename.shp -where "field1='value1'"
> > But ogrinfo return always the extent of all the shapefile not only the
> > extent of filtered one.
> This will not work. See:
<http://osgeo-org.1560.x6.nabble.com/Re-Selecting-features-using-ogrinfo-td4538045.html>
> last answer.
Use -dialect SQLITE and play a bit with the -sql parameter and I believe you
can construct a field that suits your needs. Here is a coarse example
ogrinfo -dialect sqlite -sql "select GEOMETRY,
MbrMinX(GEOMETRY),MbrMinY(GEOMETRY),MbrMaxX(GEOMETRY),MbrMaxY(GEOMETRY)from
test limit 1" test.shp
-Jukka Rahkonen-
> HTH,
> André Joost
