[gdal-dev] Call for discussion for "RFC 42: OGR Layer laundered field lookup"
Tamas Szekeres szekerest at gmail.com
Sun Oct 6 11:05:18 PDT 2013
Jürgen,
Looks like a good proposal.
The only thing I'm uncertain about whether the driver should do something
different when calling OGRLayer::FindFieldIndex with bExactMatch = TRUE
than when calling OGRLayer::GetFieldIndex? I don't see the driver
implementation in the pull request which would probably make that thing
more trivial to understand.
Best regards,
Tamas
2013/10/6 Jürgen E. <jef at norbit.de>
> Hi,
> This is a call for discussion for "RFC 42: OGR Layer laundered field
> lookup":
> http://trac.osgeo.org/gdal/wiki/rfc42_find_laundered_fields
> It proposes a new method in the OGR layer class (and a C API) to lookup
> indexes
> of fields, whose names have been altered by drivers (eg. by LAUNDER in OCI
> or
> Pg).
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
> QGIS PSC member (RM)                                   IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131006/bd15586b/attachment.html>
