[gdal-dev] /vsicurl/ and gz files
Even Rouault even.rouault at mines-paris.org
Thu Oct 10 11:58:25 PDT 2013
Le jeudi 10 octobre 2013 20:33:49, Jose Gomez-Dans a écrit :
> Hi,
> I was wondering if it's possible to use /vsitar/ to have a peek in .gz
> files, such as this one:
> http://www.globalbedo.org/GlobAlbedo29/tiles/2004/h17v04/GlobAlbedo.2004001
> .h17v04.nc.gz
This is a gzip file, not a .tar.gz file, so you would have to use /vsigzip , and
as it is a gzip file over http, you have to combine it with /vsicurl
The syntax would be :
gdalinfo
/vsigzip//vsicurl/http://www.globalbedo.org/GlobAlbedo29/tiles/2004/h17v04/GlobAlbedo.2004001.h17v04.nc.gz
But... as netCDF library doesn't use GDAL I/O natively, you would also to use
the vsipreload mechanism, available on Linux for the development version of
GDAL. See http://lists.osgeo.org/pipermail/gdal-dev/2013-May/036324.html
export LD_PRELOAD=vsipreload.so
gdalinfo
Technically, this works, but as I've just tested, it will be very inefficient
since the netCDF library asks, just after having detecting the netCDF
signature from the first bytes, for the size of the netcdf file, and the only
way to know the size of a gzipped file is to decompress it until its end, which
means that /vsicurl will have to download it entirely...
All in all, in that case, you have no choice but downloading the whole file
locally. The experience would perhaps be better (but I've not verified) if the
file was in a zip archive, that contains the uncompressed size in the metadata.
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
