[gdal-dev] /vsicurl/ and gz files
Jose Gomez-Dans jgomezdans at gmail.com
Fri Oct 11 08:54:51 PDT 2013
On 11 October 2013 15:57, Kyle Shannon <kyle at pobox.com> wrote:
> As Even mentioned, the NetCDF driver doesn't use the VSI*L mechanism,
> so you can't use /vsi*/ stuff with it unless you use
> LD_PRELOAD=vsipreload.so, see above.
OK, sorry, I thought that only applied to the /vsicurl/ method. Thanks for
the explanation.
Jose
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131011/82011071/attachment.html>
