[gdal-dev] R: Re: GDAL 1.10.1 requirements
Even Rouault even.rouault at mines-paris.org
Mon Oct 14 07:22:30 PDT 2013
Selon "lauramail at iol.it" <lauramail at iol.it>:
> Hi Even,
> I had this error with a particular HDF5, it is strange because with the
> previous version everything works (but I did not try with HDF5 1.8.9 and GDAL
> 1.9) .
> Do you know that error message?
> First of all I would like to understand if it is a library version problem or
> not. I mean, I do not think the latest version is able to read less file than
> the previous one but maybe there is something to set or different. Do you try
> this new one?
No, I didn't try. No way to test right now, and if that happens on a particular
fine, unless I'm particularly lucky, that will not be really usefull. As far as
why it doesn't work, it could be a bug in the version of the HDF5 library. Did
you try the hdf5-tools of the same version ?
