[gdal-dev] Using VRTDataSource/UnionLayer for S57 thematic layers
Even Rouault even.rouault at mines-paris.org
Fri Oct 18 12:24:03 PDT 2013
Andre,
> Having to specify each individual contributing layer with its source
> separately, while very flexible, is fairly verbose and error-prone in my
> particular case. Is there a way to specify wildcards/rules for the
> sources/layers to load?
No, no wildcard are possible.
> If not, has such an approach been considered?
Not that I'm aware of : layer unioning is a quite new feature. I guess people
who have that need would use their favorite scripting language to generate the
VRT. Perhaps a "ogrbuildvrt" script ala gdalbuildvrt could be done for that
purpose.
> Also, is there a way to create a union layer without going through the
> VRT file format? That is, through the OGR API, is there a way for a
> client application to union layers that it already opened?
You can use the UNION ALL keyword in a OGR SQL statement. See
http://gdal.org/ogr/ogr_sql.html .
Best regards,
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
