[gdal-dev] Building HDF5 driver against the binary distribution
Joaquim Luis jluis at ualg.pt
Fri Oct 18 15:31:58 PDT 2013
> Hum, this reminds me very much of the very recent thread :
> http://lists.osgeo.org/pipermail/gdal-dev/2013-October/037257.html . So there
> might indeed be an issue with HDF5 1.8.11, and not specifically related to
> Windows. I didn't try myself.
> Did you try with an older Windows build provided by the HDF_Group ? (provided
> that you can download older builds...)
I have build 1.8.11 myself and use it both in Mirone and GMT and had no
problems so far. It's linked as dll, not a  plugin but it should not matter.
Joaquim
