[gdal-dev] Rv: Support of filemapping for fast rendering in QGIS...
A Huarte ahuarte47 at yahoo.es
Tue Oct 22 05:57:54 PDT 2013
Hi, I am testing in Windows XP compiling with Visual Studio 2010.
I have a console test application using directly the "shapefil" library.
I will use test_ogrsf utility for a complete benchmark
I this environment and my test application, using OGRFastAtof(), the full read of a huge shape around 500.000 records (500mb of shp file, 150mb of dbf file) with eight double fields goes from 5.6sg to 3.06sg. I don't evaluate that the precision loss, it is a task for check.
In addition, using filemapping with boost library, the full process goes from 3.06sg to 1.45sg.
These values ​as you see ​are approximate, but they give an idea of ​​optimization is possible at least for this OS.
It is why I wanted to check this behavior
thanks!
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131022/45f9dd9c/attachment-0001.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131022/45f9dd9c/attachment-0001.txt>
