[gdal-dev] Open BIL, BIP, and BSQ raster files without header
Kyle Shannon kyle at pobox.com
Tue Oct 22 09:20:14 PDT 2013
Gabriel,
Did you look at the VRT dataset?
http://www.gdal.org/gdal_vrttut.html
I suspect that is what you are looking for.
kss
On Tue, Oct 22, 2013 at 7:27 AM, Gabriel Fusca
<gabrielfusca at suremptec.com.ar> wrote:
> Dear all,
> I'm using GDAL 1.9.1 and I would like to load binary raster files
> especifying manually header information such number of lines, number of
> pixels, pixel data type, byte order, bits per pixel.
> Also I would like to specify file offset, band offset and line offset for
> the file.
> Can someone please help me figure this out.
> Thanks in advance,
> Regards
> Gabriel Fusca
> SUR Emprendimientos Tecnológicos
> Perú 345  Piso 5to Oficina "B" (C1067AAG)
> Ciudad de Buenos Aires, Argentina
> Tel. +54 (11) 4342-2976/84
> http://www.suremptec.com/
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Kyle
