[gdal-dev] Building HDF5 driver against the binary distribution
Ivan Lucena lucena_ivan at hotmail.com
Tue Oct 22 10:37:11 PDT 2013
Hi Joaquim,
Here it says:
"The SZIP and ZLIB external libraries are optional for use
with HDF5. The HDF5 pre-compiled binary distributions  include the
SZIP (Encoder Enabled) and ZLIB libraries that they are compiled with. " [http://www.hdfgroup.org/HDF5/release/obtain5.html]
When they say "include" it means that the szip.dll and zlib.dll are there on the \HDF5\1.8.11\bin when you install the package.
Did you compiled HDF5 1.8.11 with static szip and zlib?
I build GDAL with the internal zlib. What about you?
Thanks a lot,
Ivan
> Date: Fri, 18 Oct 2013 23:31:58 +0100
> From: jluis at ualg.pt
> To: even.rouault at mines-paris.org
> CC: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Building HDF5 driver against the binary distribution
> > Hum, this reminds me very much of the very recent thread :
> > http://lists.osgeo.org/pipermail/gdal-dev/2013-October/037257.html . So there
> > might indeed be an issue with HDF5 1.8.11, and not specifically related to
> > Windows. I didn't try myself.
> > Did you try with an older Windows build provided by the HDF_Group ? (provided
> > that you can download older builds...)
> Hi,
> I have build 1.8.11 myself and use it both in Mirone and GMT and had no
> problems so far. It's linked as dll, not a  plugin but it should not matter.
> Joaquim
> gdal-dev mailing list
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131022/6836b736/attachment-0001.html>
