[gdal-dev] understanding gdalwarp default output resolution
    Ivan Marchesini
    ivan.marchesini at gmail.com
    Mon Oct 28 07:55:53 PDT 2013
Dear all,
I'm using gdalwarp to reproject a wgs84 srtm (3 arcseconds) tile to a
projected utm zone. I do not set "-tr" or "-ts" options, hence the final
output resolution is estimated by the gdalwarp module itself.
For my tile I obtained an output resolution of 81.19 meters and I'm
wondering if one could explain which is the rationale behind this value.
Many thanks
Ivan
