[gdal-dev] Satellite projections
Jerl Simpson jsimpson at wxtrends.com
Mon Oct 28 09:01:07 PDT 2013
Hi Reinoud:
I've had moderate success using the info and JAR file found here:
http://www.ssec.wisc.edu/visit/netcdf/
It converts the GOES East/West, MTSTAT, and METEOSAT data to netCDF.
I can then use gdaldem to get an image.  I'm working on assigning the SRS
info now, thanks to Simon's suggestions.
Jerl
On Mon, Oct 28, 2013 at 10:55 AM, Reinoud Bokhorst <
reinoud.bokhorst at bmtargoss.com> wrote:
>  Dear Jerl, Simon,
> Apologize for mixing into this thread but I am currently investigating how
> to process EUMETCAST data to more usuable formats like NetCDF and GeoTIFF.
> The data stream contains MSG HRIT data and GOES15/17 + MTSAT2 LRIT data.
> I'll also need to reproject like you do so this post already proves useful!
> I can read the MSG data trough gdal/meteosatlib but I can't read the GOES
> and MTSAT2 LRIT data yet. Do you perhaps have some useful pointers to
> software to use? Online documentation is rather scarce...
> Thanks Reinoud
> On 10/28/2013 04:41 PM, Jerl Simpson wrote:
> Thanks Simon!
>  I'll give it a shot.  Meteosat is definitely a pain, and it's one of the
> satellites I'm working with.
>  If you don't mind me asking, what do you typically have in your -a_ullr
> designation for gdal_translate?  Or are you pulling out sections and it
> varies?  I'd like to get the full image, if possible.
>  Thanks again!
>  Jerl
> On Mon, Oct 28, 2013 at 10:33 AM, Simon Richard Proud <srp at geo.ku.dk>wrote:
>>  Hi Jerl,
>> We work with Meteosat data in full disk projection and it's a bit of a
>> headache! Try these commands in GDAL and see if they work for you:
>>  gdal_translate -a_srs  "+proj=geos +a=6378169 +b=6356583.8 +lon_0=9.49
>> +h=35785831" -a_ullr $up_left_x $up_left_y $low_rig_x $low_rig_y $INFILE
>> $TEMPFILE
>> gdalwarp -s_srs '+proj=geos +lon_0=9.49 +h=35785831 +x_0=0.0' -t_srs
>> '+proj=latlong +datum=WGS84' -tr 0.01 0.01 -te 0 20  70 70 -order 3 $TEMPFILE
>> $OUTFILE
>>  Just remember to change the +lon_0 to whatever you need for GOES. Also
>> change the -tr and -te for gdal :-) You can also add +lat_0 but to be
>> honest I never found it made a difference (perhaps it is ignored?)
>>  Cheers,
>> Simon
>> *Fra:* gdal-dev-bounces at lists.osgeo.org [gdal-dev-bounces at lists.osgeo.org]
>> på vegne af Jerl Simpson [jsimpson at wxtrends.com]
>> *Sendt:* 28. oktober 2013 16:17
>> *Til:* gdal-dev at lists.osgeo.org
>> *Emne:* [gdal-dev] Satellite projections
>>   Hi guys:
>>  I have a few data sets that come from the GOES satellites (Full Disk)
>> and a couple others.  I can use one of the SSEC's programs to convert from
>> their format to a netCDF.  No useful SRS info comes along in the conversion.
>>  I've applied an SRS to them using gdal_translate and PROJ.4 that looks
>> like:
>> "+proj=ortho +lon_0=-79.8 +lat_0=.208"  (lon/lat is the position of one
>> of the satellites)
>>  (I've also tried):
>> +proj=ortho +datum=WGS84 +ellps=WGS84 +lon_0=-79.8 +lat_0=.208
>>  I'm wanting to get them into EPSG:4326.  When I do this, I end up with
>> corner coordinates of a very small area just below the satellites position.
>>  Does anyone have an suggestions that might help me warp this into
>> position?  I'm sure there's something obvious that I'm missing.
>> I found this page, and the copied/pasted bit about the projection, but my
>> attempts have not been successful.
>>  http://www.gdal.org/frmt_msg.html
>>  *Georeference and Projection*
>> *The images are using the Geostationary Satellite View projection. Most
>> GIS packages don't recognize this projection (we only know of ILWIS that
>> does have this projection), but gdalwarp.exe can be used to re-project the
>> images.*
>> Thanks!
> Jerl Simpson
> Sr. Systems Engineer
> Weather Trends International
> Corporate – http://www.wxtrends.com
> B2B – http://www.wt360business.com
> B2C – http://www.wt360.com
>  This communication is privileged and may contain confidential
> information. It's intended only for the use of the person or entity named
> above. If you are not the intended recipient, do not distribute or copy
> this communication. If you have received this communication in error,
> please notify the sender immediately and return the original to the email
> address above. © Copyright 2013 Weather Trends International, Inc.
> ______________________________________________________________________
> This email has been scanned by the Symantec Email Security.cloud service.
> For more information please visit http://www.symanteccloud.com
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
> Reinoud Bokhorst
> Advisor Oceanography & ICT
> BMT ARGOSS
> Tel.:         +31 527-242299
> Direct:     +31 527-656421
> Mobile:    +31 6-54714427
> www.bmt.org/linkedin | www.twitter.com/bmtgroup | www.facebook.com/bmtgroup | www.youtube.com/bmtgroupltd
> BMT ARGOSS b.v., Voorsterweg 28, 8316 PT, Marknesse, The Netherlands
> (Postal address : PO Box 61, 8325 ZH, Vollenhove, The Netherlands)
> Registered in The Netherlands, Registered no. 39060160.
> Unless otherwise agreed by BMT ARGOSS in writing, all  work, services, goods or products supplied by BMT ARGOSS shall be subject to and governed by BMT ARGOSS’s own terms and conditions which are available for inspection from BMT ARGOSS on request.
> E-mail confidentiality notice and disclaimer:
> The contents of this e-mail and any attachments are intended for the use of the mail addressee(s) shown. If you are not that person, you are not allowed to read it, to take any action based upon it or to copy it, forward, distribute or disclose the contents of it and you should please delete it from your system. BMT ARGOSS does not accept liability for any errors or omissions in the context of this e-mail or its attachments which arise as a result of internet transmission, nor accept liability for statements which are those of the author and clearly not made on behalf of BMT ARGOSS.
> Please consider the environmental impacts of printing this email, and only do so if really necessary
Jerl Simpson
Corporate – http://www.wxtrends.com****
B2B – http://www.wt360business.com****
B2C – http://www.wt360.com****
This communication is privileged and may contain confidential information.
It's intended only for the use of the person or entity named above. If you
are not the intended recipient, do not distribute or copy this
communication. If you have received this communication in error, please
notify the sender immediately and return the original to the email address
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131028/cefa9b46/attachment-0001.html>
